A new issue with my eclipse
Old Oct 18, 2006 | 06:17 AM
kscragg's Avatar
has manb(.)(.)bs
yeh i just got my car back from them few weeks ago. I would call them again, they just real busy guys, especially lately. If I can't figure out what is going on, I will most likely give them a call. But it seems pretty clearly that my water pump seal is going.. When i change my oil friday I should be able to rule out headgasket and I'll just replace my water pump most likely.
Old Oct 18, 2006 | 06:25 AM
ThE iNfAmOuS p MoNeY's Avatar
Tampa Bay Tuned Inc.
i kno it's hard not to, because i'm sure we've all done it, but try not to play the "parts changing" game...u'll def. save urself some money if u just hit up the brothers asap...they'll be more than happy to help u...they are currently finishing my car...i just saw it last night and omg...simply put, Rob and Dave are friggen amazing...hit em up bro...u'll save time and money...*
Old Oct 18, 2006 | 10:45 AM
kscragg's Avatar
has manb(.)(.)bs
so where else could the coolant be coming from?
Old Oct 23, 2006 | 12:41 PM
kscragg's Avatar
has manb(.)(.)bs
ok update on my problem... everytime i shut off the car, a ton of coolant starts spitting out of the bleed line from the overflow tank. None of the coolant even gets into the overflow tank. I called Dave and he said check the hose for clogging that leads into the overflow tank and I did, but does not seem to be clogged. Any ideas?
Old Oct 24, 2006 | 11:09 AM
kscragg's Avatar
has manb(.)(.)bs
come on guys, I know someone has to know what is going on. I replaced the radiator cap today with a pos advanced auto one until the OEM one comes in at mitsu on thursday. The cars water temp is still climbing, most of the time when im driving on the interstate. And of course, when I turn off the car it pukes a shit load of coolant out of the overflow reservoir bleed line.
Old Oct 24, 2006 | 11:41 AM
THE_ONE's Avatar
*Turbo Interceptor*
you might need to flush your radiator and replace the thermistat.
Old Oct 24, 2006 | 12:15 PM
  #17 (permalink)
kscragg's Avatar
has manb(.)(.)bs
think i found my answer on dsmtalk forum. People are having the same problem when there headgasket has been the culprit. Sighhhhhhhhhhhhhhh, how much does this usually cost to get replaced and/or how hard is this to do on my own..
Old Oct 24, 2006 | 12:19 PM
  #18 (permalink)
THE_ONE's Avatar
*Turbo Interceptor*
man you should have the Brothers do that or jerry. I don't know about you but timing being wrong can cause a lot of heart ach......
Old Oct 24, 2006 | 12:46 PM
  #19 (permalink)
kscragg's Avatar
has manb(.)(.)bs
yeh i just called rob, and he threw me a good deal for replacing my headgasket ( as always ). So that will be done on friday . Just a few more issues to fix and my car will be on autotrader.
