Head And Block Quote
Old Sep 5, 2006 | 12:27 PM
Green_Lantern's Avatar
Green Lantern Corps
Default Head And Block Quote
I went to a machine shop today to get a quote for the head and block. They quoted the head for $300 and the block for $1800. They are a very reliable shop and do some impressive work. But I was just wondering if these were reasonable prices? And if not what are the most common prices that shops charge? Thanks for the input
If you're not cracking oil pans your not low
Old Sep 5, 2006 | 01:00 PM
GsEclipse02's Avatar
was this a built bottom end ? and a stock head with new valve stems or something ?
Old Sep 5, 2006 | 01:22 PM
Green Lantern Corps
Well im buying all the shit for the head and the block seperate from the place i take it to. They were just gonna charge me for the install of the parts and labor.
Old Sep 5, 2006 | 02:16 PM
hunntyr's Avatar
Jesus, what are they charging you in labor? If a person doing a rebuild knew what they were doing and they devoted their whole attention to it, it should only take between 15 - 20 hours to remove the old motor, assemble the new one and reinstall assuming every single part was available. Hell, if there were more than one person it would take less time. At $75/hr for labor @ 20 hrs only comes to $1500 + tax and disposal fees.
Are you having anything ordered? Do you have EVERYTHING to rebuild the kit such as a full rebuild gasket set? I have found that if the shops have to use "their money" to order your parts, they tack on a little extra to make money on that end as well.
Old Sep 5, 2006 | 03:03 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
see if jerry can get you something honestly.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Sep 5, 2006 | 03:38 PM
Green Lantern Corps
No not from them. I'm ordering all the stuff from different areas. Then I'm having them put it all together. But the only thing I'm going to need is the gasket set which hopefully i can get from the place where i get the work done.
Old Sep 5, 2006 | 04:57 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
is it 1800 for just labor and machining? if its 1800 including the price of rods/pistons/crank etc. then it had better be a built motor. my bottom end costed me 1600 dollars, everything uncluded, put together.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Sep 8, 2006 | 11:53 AM
Green Lantern Corps
Ya its 1800 for the machining and instal of the parts i have to buy seperate. To me it sounds expensive but i dont really know cuz this is the first car i've ever had to get machine work done to.
Old Sep 8, 2006 | 12:06 PM
lancerman's Avatar
Wow... you are getting it up the ass. If it isnt too late, you need to take your business elsewhere. They are overcharging you considerably!
my favorite quote
Old Sep 8, 2006 | 12:19 PM
dsmdreamer's Avatar
well it also depends what is the work he needs. is it just a str8 rebuild? or are you boreing the motor out etc?
im in orlando and i go to REVmaster for all my rebuild work. i had a 1g head that had bent all but 2 valves. the did the rebuild with porting and parts for like $400
