88 starion problems
Old Aug 5, 2006 | 02:13 PM
Minimechanic's Avatar
EII Autowerkz
Default 88 starion problems
My buddy has a 88 starion that breaks up at 4000 rpm's. He has replaced the injectors and has looked for vaccum leaks. Let me know what u guys think it could be. If u need more info let me know.
Old Aug 5, 2006 | 02:17 PM
JR.'s Avatar
JR.
boost leaks
98 talon awd automagic
Old Aug 5, 2006 | 03:34 PM
Figs's Avatar
Originally Posted by qbanjr9
boost leaks
+1
Old Aug 8, 2006 | 06:17 AM
Kristin's Avatar
call me Gangsta boo
Did you guys figure it out??
I can't find a boost leak on mine but I have a sneaky feeling that I have one.
Please check out this link...
http://www.BeautysEquineRescue.org
Old Aug 8, 2006 | 06:47 PM
GsEclipse02's Avatar
did u do a boost leak test or just looked at it ?
Old Aug 12, 2006 | 05:01 PM
SHhhhh's Avatar
a bad vacuum advance will also cause this. also check injector clips.
Old Aug 12, 2006 | 09:33 PM
charlie31603's Avatar
I do what I want.
+1. I had the same problem on my old 87 starion. Just putting new injector clips helped out alot. The secondary injector kick's in around that time. Adam
http://www.cardomain.com/id/charlie31603
1987 Chevrolet Camaro Z28(IROC)
Old Aug 14, 2006 | 04:37 PM
EII Autowerkz
I havent checked for boost leaks but we have replaced the injector but havent replaced the clip. How can I check the vacuum advance?
Old Aug 14, 2006 | 05:30 PM
I do what I want.
The clips are like the #1 problem on these cars. So make sure you change those. You can check the vacum advance buy sucking on the hose that gose to it and see if it will stay sucked to your tounge. If not it's bad. Adam
If you haven't allready got to home redirect. It's the best site around for these cars. They have every posabile problem allready fixed with a sulition.
