BOV question
Old Jan 31, 2006 | 09:14 AM
  #21 (permalink)
eclipsegst303's Avatar
.:DSM:.
Well, your in luck! I have my HKS hooked up to a greddy flange. Below is how to do it. Made this just for you, or anyone else who may want to do it...
Just make sure the nuts and bolts are tight, and do a leaktest after wards. I've never had a problem with mine like this.
Oh and when buying/using the smaller washer(blue), make sure its not thicker than the base "disk" of the HKS bov.Obviously if it is, then the big washers(red) wont be able to press down tight on the base of the BOV.
Its easy once you actually start doing it.
Old Jan 31, 2006 | 11:12 AM
  #22 (permalink)
Dario99gst's Avatar
Tu Papi Chulo
rep points for you for being the most helpful in the whole thread.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jan 31, 2006 | 11:23 AM
  #23 (permalink)
00eclipseGT's Avatar
Infinite limitz
Definately big props. Great picture too!
Old Jan 31, 2006 | 12:00 PM
  #24 (permalink)
LS1Fever's Avatar
Damn Richard, thats pretty good man. Good info too.
Old Jan 31, 2006 | 12:14 PM
  #25 (permalink)
.:DSM:.
thanks john
Old Jan 31, 2006 | 10:38 PM
  #26 (permalink)
Jordan Y.'s Avatar
15 seconds EXHILARATION
Originally Posted by Josiah
heh, if you want cheap I still suggest that 1st gen DSM BOV mod...$7 for a dsm unit from the junkyard($80 new) and maybe $20 to mod it to hold 30psi...why would you need anything else?
Modding the 1g bov in that manner slows the response when the port is referenced to atmosphere and can cause the turbo to stall and surge before the BOV opens. It works great when you hook it up to a solenoid and can switch it to high boost mode for limited use, but it's not very good for an application that's going to see over 18 psi all of the time.
Old Feb 2, 2006 | 07:39 AM
  #27 (permalink)
.:DSM:.
Hmmmm, that guy that needed help never even came back....Thanks for the rep points guys.
Old Feb 9, 2006 | 05:38 AM
  #28 (permalink)
slvrblt's Avatar
I've been back a few times...just didn't post....thanks for the info
Old Feb 9, 2006 | 06:03 AM
  #29 (permalink)
MightyMaxGS-T's Avatar
i use the greddy type r....that is made for big boost, when u see it you'll know what im talking about...
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Feb 9, 2006 | 12:21 PM
  #30 (permalink)
TunerElite's Avatar
The Right-Wing
Tial +1
