4g63 problems
Old Jan 15, 2006 | 03:02 PM
naciamaj's Avatar
MY LIFE, YOUR VACATION
Unhappy 4g63 problems
For some reason when I am in boost my car will start to hesitate as if the injectors are fouling. I am not getting any signs from my turbo as if it were going bad and I have the boost set to low. I almost want to say that it could be my stock intercooler piping going bad. Any help is appreciated.
"She told me it's just a car, I told her shes just a girl."
AIM : SurferDudeCLW
[url]http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=491 27763
Old Jan 15, 2006 | 03:09 PM
Dario99gst's Avatar
Tu Papi Chulo
When was the last time you changed your plugs and wires?
Have you done a boost leak test?
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jan 15, 2006 | 03:18 PM
Josiah's Avatar
Peon on steroids!
what do you mean hesitate? does it misfire? splutter? just lack power? if its spluttering its most likely a fuel issue(injectors, filter, fuel pump, etc)
Old Jan 15, 2006 | 03:37 PM
naciamaj's Avatar
Well I took my car to mitsubishi to get an engine flush and my fuel system cleaned. They also ran a diagnostic on my car and said that nothing was wrong. My iridium spark plugs are fairly new and I bought some new wires like a couple weeks ago. When I say that it hesitates it almost spudders but not bad. It will do this if I get passed 3 grand and have the peddle more than 30%. I am kinda lost.
AIM : SurferDudeCLW
Old Jan 15, 2006 | 03:38 PM
Dario99gst's Avatar
Tu Papi Chulo
ok that rules out fuel and spark. have you checked for boost leaks?
-Dario
Old Jan 15, 2006 | 03:59 PM
naciamaj's Avatar
No how do I go about doing that?
AIM : SurferDudeCLW
Old Jan 15, 2006 | 04:12 PM
Dario99gst's Avatar
Tu Papi Chulo
the best way is to go to home depo and buy a rubber coupling the size of your turbo inlet make a small hole in the middle then using an air hose with a blower fitting blow air in through the turbo and then seal the hole with your finger and listen for any air escaping.
-Dario
Old Jan 16, 2006 | 02:39 AM
Autobot's Avatar
4G63er
Originally Posted by naciamaj
My iridium spark plugs are fairly new.
Use NGK BPR6ES instead. or BPR7ES depending on your mods.
Old Jan 16, 2006 | 06:50 AM
boosteddsm's Avatar
Awd the enemy of fwd
another way similiar to what dario said is to get a rubber coupling from home depot in the plumbing section and also get a pvc end cap that will fit in the end of the rubber coupling and drill a hole in it, and put a valve stem in it.
Go to the gas station fill it with air and listen for a leak.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old Jan 16, 2006 | 07:28 PM
Brothers's Avatar
TR Balla Donor Supreme
well iridium plugs suck for dsm get rid of those for a start go with bpr7es or 6es if not change your wires but use stock wires from the dealer dont use the ones they sell at discount they suck also. and also is your car a complete 6 bolt or 7 bolt?
FullyBuiltInc.com
Brothers
A.K.A
Rob and Dave
