4g63 problems
Old Jan 21, 2006 | 04:37 PM
naciamaj's Avatar
MY LIFE, YOUR VACATION
Well heres what I am going to do. I am going to overhaul my engine cause it needs it anyway. Buy some 2 1/2 inch ic piping, new wires (I bought the ones from discount) so I am going to go to the dealership and get new ones, pick up a 3rd gen. evo turbo, and I was wondering if you could help me out with some good injectors for this (cheap for now).
"She told me it's just a car, I told her shes just a girl."
AIM : SurferDudeCLW
[url]http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=491 27763
Old Jan 21, 2006 | 05:04 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
like, is it not moving AT ALL, or moves after a little. cause my intake wasnt perfectly attached to the turbo, and it would sputter and not go very well. sef. sounds like intake leak.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jan 21, 2006 | 06:36 PM
FastEclipseGSXT's Avatar
sounds to me like its missing I.E. from ingnition failure, i used bpr7es flawlessly, make sure you have a PROPER GAP as well, i used 28thousands and still had good fuel mileage
Jeremy
www.myspace.com/biggrapes01
Old Jan 21, 2006 | 07:50 PM
flybyuin2.2's Avatar
you should change the spark plugs and go with NGK's anytime you do a fuel injector service the plugs take a beating and in many cases new plugs are needed.
Old Jan 22, 2006 | 07:24 PM
25 to LIFE's Avatar
Default abc
do this, your gap may be to wide, and junk those spark plugs, the fancy name and good marketing is what sells those, not performance in my opinion. i have had better luck with the NGK bpr7es, its a colder plug.
just wondering, do you have a boost controler (boost turned way up and not enough fuel to compensate =detonation) without the other needed items or some other messed up combo? also what octane are you running? cheap gas+boost+high revs=pits in pistons, so I've seen. has your car sat? and blah, blah, blah, blah???????????
Old Jan 22, 2006 | 08:20 PM
Styl129's Avatar
Sounds like you have a bad MAFS, oR a boost leak,also i can get you 7mm NGK spark plug wires for about $50 they are great wires.
Old Jan 23, 2006 | 05:06 AM
  #17 (permalink)
Dario99gst's Avatar
Tu Papi Chulo
I would fix the problem you have now before you go and do anything else.
Did you get new plugs and wires? also someone said the mas might be bad check with gseclipse02 he has 2 of them.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jan 23, 2006 | 06:11 AM
  #18 (permalink)
GsEclipse02's Avatar
yes i do just pm me or call and ask for julian 813-843-4499
thanks dario
Old Jan 23, 2006 | 06:22 AM
  #19 (permalink)
DeadSexY's Avatar
diballacully slow
I almost want to say that it could be my stock intercooler piping going bad.
Old Jan 23, 2006 | 12:59 PM
  #20 (permalink)
naciamaj's Avatar
No I always put in 93 or higher in my car. Intake and everything is straight, everything is where it needs to be. It's in working progress right now will let you know what happens when I am done.
AIM : SurferDudeCLW
