PLX M-300 Wideband problem...
Old Nov 18, 2005 | 12:40 PM
SilverTurbo's Avatar
It's Alive!!!!!
Default PLX M-300 Wideband problem...
Here's another problem I am facing... The wideband unit reads 14.7 the whole enitre time. It doesn't change higher or lower. The sensor works because we tried it on another vehicle. What do you think the problem is coming from? The unit it self or the o2 sensor wire harness????
-SilverTurbo has future plans in mind...
Old Nov 18, 2005 | 01:29 PM
GsEclipse02's Avatar
your alive... pm and let me know how every thing is going with the car
Old Nov 18, 2005 | 04:09 PM
Tom N's Avatar
Non DSM.....DSM guy
Exactly how do you have it hooked up.
Are you using a guage, logging it, both.
Where is it grounded.
Tom
Old Nov 18, 2005 | 07:00 PM
It's Alive!!!!!
The unit is connected directly to the battery so when the car is running it's on. i'm not sure where it's grounded but i will found out. I didn't install it. If the unit wasn't grounded correctly, it would not even turn on...right???
Old Nov 18, 2005 | 09:09 PM
Tom N's Avatar
Non DSM.....DSM guy
It should be hooked up to key on power.
Not sure why you would hook it up strait to the battery but thats wrong.
I take it you are using the 52mm gauge with it and not logging it with dsm link or aem, etc.
Tom
Old Nov 18, 2005 | 11:04 PM
i dont think he is logging ... he doesnt not have dsm link or aem ... its a 420a ...
good luck with it ...
Old Nov 19, 2005 | 09:17 AM
91TSI_AWD's Avatar
Resident Galant Guy
if the gauge is reading total lean all the time, then it means its not getting a signal thus reading 0 volts. meaning total lean. Your sensor might work, but its not hooked up to the gauge.
Mike
95 Lancer GSR
93 300ZX 2+2
Old Nov 19, 2005 | 01:22 PM
It's Alive!!!!!
I know when it's lean, which is an extremely bad thing, but i know how the car runs when it's lean (past experience)... it's running good now. no white smoke. I think i'm going to check the ground first then the wire harness... It has to be one of those two. Oh and by the way, i did give false info. the unit is connected to the ignition like TOM N said.
Old Nov 20, 2005 | 01:06 AM
Tom N's Avatar
Non DSM.....DSM guy
What color is the wire thats hooked to the gauge?
Tom
Old Nov 21, 2005 | 09:45 AM
Rich's Avatar
Old School.
Call PLX, they're helpful.
You may know who we are, but we KNOW who you are.
