merrrrrrr
Old Oct 15, 2005 | 02:47 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Damn man that sucks Did you try to prime the pump and see if it leaks.
Old Oct 15, 2005 | 08:35 AM
goat's Avatar
no but im gonna waste all day today waiting for it. nothing like watching gas leak to work out a hangover
Old Oct 15, 2005 | 09:53 AM
Brandon's Avatar
Resident Dingo
no we did prime the pump and nothing happened. I agree with a watched pot never boils, that car is stubborn.
Old Oct 17, 2005 | 12:25 PM
goat's Avatar
alright, went out, turned car on, pulled back seat out and screwed off cover to pump exposing the lines/electronics. not leaking, dry as a boner. i drive it around for a couple minutes and slowly the area it starts getting wet with gasoline, it started seeping in from what looks like to be the inside of that plastic O ring, and on the outside of the area (i guess the top of the gas tank?) it was wet with gas too.
im still clueless but im just gonna unscrew that plastic ring and screw it back on, thats all i can think of for now.
Old Oct 17, 2005 | 01:43 PM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
Are you talking the oring on the fuel pump?
Old Oct 17, 2005 | 03:43 PM
goat's Avatar
i thought i was but apparently the O ring is a lot smaller. my O ring was fucked up a while ago, giving me hardcore fuel problems.
i took off the plastic ring, put it back on as tight as i could and i got on it up and down the street, and so far no leaking. hope thats all the problem was
Old Oct 17, 2005 | 04:55 PM
  #17 (permalink)
BoosTb4BroaDs's Avatar
Does the ring have a gasket??
Old Oct 17, 2005 | 05:07 PM
  #18 (permalink)
Brandon's Avatar
Resident Dingo
I'm pretty sure it has a rubber gimmick to keep the seal inside of that plastic ring
Old Oct 17, 2005 | 06:22 PM
  #19 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
mine was leaking right at the beginning of the fuel return line....had me mad for a while until i looked right infront of me!
-Dane
98 240 w/ bolt-ons
Srqspeed.com
