over heating
Old Sep 1, 2005 | 11:50 AM
DeadSexY's Avatar
diballacully slow
Default over heating
god damnit im over heating after i do a pull and that with 2 1250 cfm fans on high.i looking where to buy a gallon or two of water wetter locally. and ill take any tips you guys may have.
thanks
juan
Old Sep 1, 2005 | 12:01 PM
LS1Fever's Avatar
damn man, that sucks. check your thermostat and see if its sticking. bring it by here, i want to see it!
Old Sep 1, 2005 | 07:24 PM
Ender.'s Avatar
Eis Aner Oudeis Aner
They should sell water wetter at advanced. I bought mine there a while ago. Im not sure if by the gallon though...
Old Sep 1, 2005 | 08:31 PM
dsm_90's Avatar
fast, faster, gone
your problem might not be solved with water wetter, you need to figure out what's causing the overheating before you do some serious damage....
frequency
Old Sep 1, 2005 | 09:00 PM
Ender.'s Avatar
Thermostat is probably the easiest thing ever to do on the car, almost as easy as starting it every morning. Swap it out and see what happens.
Old Sep 2, 2005 | 07:05 AM
FastEclipseGSXT's Avatar
any white puffing smoke? losing water?
Jeremy
www.myspace.com/biggrapes01
Old Sep 2, 2005 | 12:44 PM
dsm's Avatar
dsm
rice sleeper
yea do what some of these guys are saying. i was having problems with overheating, thought it was fixed but its still over heating a little, but only when im stopped at a light. as soon as i get moving it goes back to normal. check the thermostat, leaks, radiator etc. anything to do with cooling. i know i will be soon.
2010 Evo X MR
12.3@110mph
344whp/375wtq
Jalvarez Studio
Old Sep 2, 2005 | 04:59 PM
Autobot's Avatar
4G63er
mine did the same before, got hot when at a stop but then went back down as soon as the car got moving. I replaced thermostat and flushed my coolant and it's all good now.
Old Sep 3, 2005 | 08:28 AM
same problem here and i found out that i had a crack on the cap of the radiator reservoir, as the water expanded it leaked and evaporated, jb weld did the trick
Jeremy
Old Sep 3, 2005 | 01:14 PM
DeadSexY's Avatar
diballacully slow
I replaced the thermostat with a 180 when I was doing my build and I checked everything and I have not leaks and no smoke coming out the tail pipe. It likes to over heat when im at a light or with the a/c on and it go’s a way when I start moving again just like dsm. Im thinking about a vented hood and a 3rd fan. this should work.
ill keep you guys updated.
Thanks for all the replays
Later
Juan
