over heating
Old Sep 3, 2005 | 07:49 PM
dsm's Avatar
dsm
rice sleeper
Originally Posted by imdeadsexy
I replaced the thermostat with a 180 when I was doing my build and I checked everything and I have not leaks and no smoke coming out the tail pipe. It likes to over heat when im at a light or with the a/c on and it go’s a way when I start moving again just like dsm. Im thinking about a vented hood and a 3rd fan. this should work.
ill keep you guys updated.
Thanks for all the replays
Later
Juan
theres has to be another solution to this. cuz its not suppose to happen. im going to try and change the thermostat, radiator cap, and flush out the whole radiator or just replace it to see if thats the problem. i only have one fan running on the car, and its been like that for yrs, so i dont think another fan will help. but ill let you know what i find out too.
2010 Evo X MR
12.3@110mph
344whp/375wtq
Jalvarez Studio
Old Sep 4, 2005 | 10:16 AM
DeadSexY's Avatar
diballacully slow
plz do ill keep you updated
Old Sep 4, 2005 | 10:56 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Agreed with dsm. You are just simply putting band-aids on this problem. There is no reason there should be 3 fans on your car. Are you certain the fans are rotating in the correct order? Ive seen it happen before.
SUCH IS THE RULE OF HONOUR.
Old Sep 4, 2005 | 12:54 PM
DeadSexY's Avatar
diballacully slow
The reason I think im over heating is that my aftermarket fan just don’t flow as much air as did the factory ones. And If you look at the shroud on the stock fan and then the slim line you can see that the aftermarket fans just suck ass and can perform as good as factory.
But I can be wrong.
juan
