turbo question
Old Aug 12, 2005 | 07:01 PM
tampatsi21's Avatar
Ian
Default turbo question
ok, i'm doing a 6 bolt swap in my 2g and im planning on useing the stock t25 for right now, my quesion is do i have to run coolant lines to it or can i block them sice the 6 bolt dosnt have lines for turbos, or could i use the waterpipe from my 7 bolt on the 6 bolt? thanks for your time
Old Aug 12, 2005 | 07:23 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
You dont have to run coolant lines. This will probably start up a big thing again.
SUCH IS THE RULE OF HONOUR.
Old Aug 12, 2005 | 07:27 PM
tampatsi21's Avatar
Ian
ok thanks
Old Aug 13, 2005 | 01:34 PM
FastEclipseGSXT's Avatar
hahaha if you like to be entertained you have to read this thread on water lines!
https://www.tamparacing.com/forums/s...d.php?t=248395
Jeremy
www.myspace.com/biggrapes01
Old Aug 13, 2005 | 05:37 PM
tampatsi21's Avatar
Ian
im just going to go with slowboost on this one and not run them.
Old Aug 13, 2005 | 09:03 PM
bagabonesGSX's Avatar
bro, buy a 14B from one of us for like 80 bucks.....
Old Aug 14, 2005 | 09:35 AM
goat's Avatar
yeah man, if you're doing the whole swap, you might as well stick a 14b on.
Old Aug 14, 2005 | 01:03 PM
tsispyder97's Avatar
or even a 13b, its sitll bigger than a t25
Old Aug 14, 2005 | 04:42 PM
tampatsi21's Avatar
Ian
yeah i know i should i probably will one of these days but now im spening everything i have on getting the motor finished
