eliminating water lines to turbo
Old Jul 18, 2005 | 09:26 AM
2g fatkid's Avatar
Default eliminating water lines to turbo
anyone have any thoughts on this or is it a waste of my time. i am hopefully finishing the build on the car this weekend and was wondering if i should just add this to the list since i am going to be swapping turbos till i finish the work on my hrc20g. lmk your thoughts.
thanks in advance,
David
last time my car and i had a conversation it told me that when it grows up it wants to be like the Goodwill project race car.
car looks bad ass joe, it has come a long way since i saw you and mike putting the new door panels on it at mikes. keep up the good work.
1991 Eclipse GSX
2000 Dodge Dakota R/T
Old Jul 18, 2005 | 09:48 AM
cavalierchamp's Avatar
Not all turbos are meant to run without water lines.
Car is SOLD. Worst decision ever.
Old Jul 18, 2005 | 10:52 AM
Chris LS's Avatar
just blaze...
Yeah, if you want your turbo to last and it needs water, then run the lines. It won't last long w/out it.
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Jul 18, 2005 | 11:55 AM
elitist's Avatar
TR Balla Donor Supreme
There is always a reason why something is made the way it is, I wouldn't mess with it...it's not worth having to either rebuild or buy a new turbo
Old Jul 18, 2005 | 02:45 PM
Ian MMF's Avatar
Omnipotence
You only need water lines if you are running a BB turbo. Otherwise pull the water lines off and just use a turbo timer. You do NOT have to have water lines unless you are running a ball-bearing turbo. It will NOT have any effects on the life of the turbo or performance, HOWEVER the use of a turbo timer will.
Old Jul 18, 2005 | 03:04 PM
I'm going to have to respectfully disagree. The T25 is a conventional bearing turbo, and Mitsubishi engineers did not run water lines to the turbo for fun. Turbo manufacturers don't include coolant inlets and outlets in turbo center sections for fun either. In my opinion, they are there to be used. There is a thread on DSMTuners in which one of the moderators removed the water lines from his T25, and grenaded the turbo a couple of weeks later because of it.
This isn't to say that you can't run low boost without water lines without blowing your turbo, but if you plan on boosting hard and often, like most DSMers do, you should have water running through the turbo to pull unnecessary heat away from it. Just like turbo timers let oil run out of the turbo and cool down without baking in the bearing journals, water lines generally cool the center section and maintain an operating temp that will lengthen the life of your turbo.
In the end, coolant lines aren't that much of a hassle. You hook them up, and then they just sit there. Mine will remain intact
Old Jul 18, 2005 | 03:39 PM
Ian MMF's Avatar
Omnipotence
I know you did not post quoting dsmtards.
I ran my 14b for quite a while with no water lines and no problems. I know people running 14b's, 20g's, evo316g's, 61mm+ sized turbo's all with no oil lines. I guess they are all wrong also and their cars are just ticketing time bombs?
You are right, they don't include the water lines for fun. They include them for retards who don't know how to use turbo cars the right way and know that you have to let them cool down.
I'll ask you this, if the whole point of a turbo is using hot gas to spin a turbine cause hot gas moves faster, why would you want to cool things down?
Maybe I don't know anything or maybe you should stop looking at tuners for "information".
*edit* Please prove your statement in some way and not by quoting t00ners.
Old Jul 18, 2005 | 03:46 PM
DeadSexY's Avatar
diballacully slow
ibtl
Old Jul 18, 2005 | 05:21 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
+1
SUCH IS THE RULE OF HONOUR.
Old Jul 18, 2005 | 05:51 PM
Dario99gst's Avatar
Tu Papi Chulo
4dr go back and edit you said they arent running oil lines I hope that is not true and I know you meant water lines but just so some idiot doesnt go and try it you may want to edit that.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
