exhuast shop/welding
the car is running well. ive been having ignition problms since i got it back. id put the key in and try to start it and it wont turn, take it our turn it over, wont turn, rince and repeat, for like 5-10 minutes before it finally turns.. i didnt have that problem before dropping it off.
Also my music wasn't working when i got it back so i checked my amp: no power, so i check my power line to my amp, and i saw that the plastic cover/case holding in my fuse was broken, the power line was wrapped too tightly around one of the cables to my battey, and then zip tied off. some duct tape fixed that for now
other than that its running fine. putting the DP on i did notice some really shitty looking grease oozing down my oil pan. one guy thought it might be coming from my CV boot, which he said might need to be replaced.
jason, i dont think i can run open DP, rememeber 2g's have 2nd O2 sensor, wouldnt that cause it to run poorly?
edit: yeah vietnam test tommorow at 6.
2ND o2 if it is off doesnt afect anything i havent had one for 3 years all you will get is a check engine light
