car problems
i was driving to work the other day and everything was running fine. right before i pull in to work, a white gsx pulls up next to me and we run em, and i hit 20-25psi or so. i pulled into work, parked the car and shut it off. about two hours later, i tried to leave to get some lunch, and the car was extremely hesitant to start. the rpms would hover around 500 for a few seconds, then die out. when i pressed on the gas, the fuel response was really laggy, and as soon as the boost gauge hit 0psi, it would sound like a misfire or timing off. on the vpc, i had the crank the fuel up like 200% of what i usually drive with just to get it home. i was able to get into about 5psi of boost, but very roughly. during the ride home, i tried to turn down the fuel, but it just kept stalling out. anyone have any ideas?
so far:
changed the spark plugs
checked for vacuum leaks
ran obd II scan (no codes)
radiator flush - not pertaining to the problem, but needed to be done
tightened down all nuts and bolts, etc.
so far:
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Russ
03 Infiniti G35
01 Lexus IS 300
checked all the vacuum lines and electrical. but just in case if i missed an elcetrical connection, wouldnt the obd 2 scan pull that up? usually a code would pop up saying "---- circuit". also, i'm running vpc/gcc, so no maf. its weird because there was no warning of this.
Russ
03 Infiniti G35
01 Lexus IS 300
Russ
03 Infiniti G35
01 Lexus IS 300
Originally Posted by Dario99gst
not again!!!!!
Russ
03 Infiniti G35
01 Lexus IS 300
Russ
03 Infiniti G35
01 Lexus IS 300
what are you thinking could have blown? the brothers rebuilt my head about 600 miles ago and i got new valves and head gasket. i don't know if this means anything tho
Russ
03 Infiniti G35
01 Lexus IS 300
Russ
03 Infiniti G35
01 Lexus IS 300
you checked all the vacuum lines but did you check them for cracks or holes.it sounds to me like a hose popped off either the fpr or the vpc map sensor.
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
checked the fpr, all hoses were on. just to double check, there is a map sensor for the car and a map sensor for the vpc, right? also, if there is one for the vpc, is it in the engine bay or would it be near the actual electronics? thanks. i don't know too much about ems
Russ
03 Infiniti G35
01 Lexus IS 300
Russ
03 Infiniti G35
01 Lexus IS 300
