car problems
Originally Posted by russellbeermann
checked the fpr, all hoses were on. just to double check, there is a map sensor for the car and a map sensor for the vpc, right? also, if there is one for the vpc, is it in the engine bay or would it be near the actual electronics? thanks. i don't know too much about ems
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
i had the crank the fuel up like 200% of what i usually drive with just to get it home. i was able to get into about 5psi of boost, but very roughly. during the ride home, i tried to turn down the fuel, but it just kept stalling out.
You may know who we are, but we KNOW who you are.
inspected all vacuum lines and gaskets, and then sprayed carb cleaner over all of them
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Russ
03 Infiniti G35
01 Lexus IS 300
I know I sound like a broken record in a lot of these help threads but I know first hand how easy it is to spring a boost leak and how much of a pain in the ass they are. Maybe I've had unusually bad luck with breaking a couple seams in a quality FMIC, ripping high dollar silicone couplers, busting fuel injector seals, but I doubt that I'm the only one.
my buddy has a boost leak tester. i will try that. another problem now, i think my power steering pump is out. got the car to run (barely) today and had no power steering. there was plenty of fluid and the belt was good. most likely the pump went out
Russ
03 Infiniti G35
01 Lexus IS 300
Russ
03 Infiniti G35
01 Lexus IS 300
Off topic... you ever play pool anymore man? I still remember the good 'ol Veterans times back in 97-99.
alright, got the problem fixed. it ended up being the ground for the coil pack, the wire had started coming apart, which = bad misfire. i appreciate everyone's help on this.
and to answer your question rich, i still shoot once in awhile at peabody's. any time you want to shoot, give me a call. 813-843-0669.
Russ
03 Infiniti G35
01 Lexus IS 300
Russ
03 Infiniti G35
01 Lexus IS 300
glad to see you fixed your dsm problem of the week
what next...
what next...
