idle surge problem
Originally Posted by BoosTb4BroaDs
isc
--brandon
Originally Posted by Philly Blunt
is there any link on how to do this? because there is no coolant on the throttle body and i did not take it off so i would like a link on what to check for
SUCH IS THE RULE OF HONOUR.
if you take the bottom half off the TB, youll see 2 air passages. One is for the ISC, and the other goes to the FIAV. basically take that half off. fill with JB weld... let sit 24 hrs, and then reassemble. now absolutly no air can go in the FIAV passage.
Mike
95 Lancer GSR
93 300ZX 2+2
Mike
95 Lancer GSR
93 300ZX 2+2
well we did the faiv block off and changed ecu's off a good running car so tomm we try the maf
still has a surge
still has a surge
I saw the ISC was replaced, but are you sure it's good?
-Jim
“Equality, rightly understood as our founding fathers understood it, leads to liberty and to the emancipation of creative differences; wrongly understood, as it has been so tragically in our time, it leads first to conformity and then to despotism”-Barry Goldwater
-Jim
