SAFCII tech question.
ok...I got an SAFCII and hooked it up over the weekend. Took some time to do the tuning and got the car running good again. Now I wanted to ask how many people have the blue wire mod done and how accurate is it?? Reason why I ask is because I have the autometer A/F Gauge (blinky light one) and the blue wire mod to actually read voltage. During idle the SAFC reads between .70 - .79 on voltage but my A/F gauge dances between lean and goes 1 green into rich. I know standard O2 voltage should be between .88 - .92 however no matter what adjustments I do on the SAFC, I can't get it to richen up during idle. Any Suggestions??
Originally Posted by 44PIRATE
Blue wire mod is a no no. Degrades the signal to the ECU.
Narrowband o2 sensors / gauges are worthless for tuning, I wouldn't go through any of the trouble that you are going through. Also, if you are actually running lean @ idle and can't correct with the AFC, you likely have a vaccuum leak somewhere.
You may know who we are, but we KNOW who you are.
Fermunky
11-29-2003 09:49 AM
