Tech Question: Compression
Question: Explain how compression is lost and how a cylinder goes completely dead.
*no this did not happen to either of my engines; i am just wanting to learn more*
thanx. angela
thanx. angela
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
If your HG is blown your cylinder isn't airtight, it's like blowing air into your hand, it leaks through the cracks. Pretty much the same if your rings get bad enough.
Guest
Posts: n/a
yup.
In order to have compression in a cylinder, you must have an air tight seal in the chambers. If you have leaky rings, or a blown HG, you will have lower, or no compression. With out compression you have shitty fire, and a shitty running car.
You guys forgot to mention that loss of compression can be created by bent valves & valve seals etc..
Originally posted by theebluecrx
Also breaking in a motor incorrectly will cause this.Low boost means low boost!
You are trying to say, not letting rings seat will cause shitty compression numbers because the rings never seated properly etc.
Where is a place to get a compression test done????? Also how can you easily find out if your car is not up to par by your standards........would a quick tune from secret sevices benefit this prob?? Or would a very educated mechanic???
TR Hydroponics Abuser #36329
J a s o0o n: i need to get piss ass shit face fuck bag bitch ass drunk god damn
thank u everybody
...91 SMF SCCA
Compression test is easy. Pick up a compression tester from Sears or some auto store. Very self explanitory. Bad compression usually can only be fixed through mechanical means like re-ringing a bottom end or reseating straight vlaves on a head. Too tight of a valve adjustment can cause a loss of compression too. A motor with really big cams causes alot of overlap and a loss of dynamic compression when when compression tested. This is th reason motors with big cams like a high static compression ratio......blah blah blah
Gracie Barra Clearwater
