Tech Question: Compression
Originally posted by JimmyHat
A Good way to check this is by putting oil in the cylinder above the piston, then try a compression test. if you get the same compression you had before then you can bet its the rings or the valves.its the rings if the oil leaks through and goes right to the oil pan. If its still there then its your valves.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
no what I ment was if you test with the oil in the cylinder and you get the same compression that means that the valves are screwed and the compression is leaking out through the valves. know what im talking about?the oil is still there?
THe best way to find out where they are leaking and where you are losing compression from after doing a compression test is by doing a leakdown test on the suspect cylinder.
once you do the leak down test and air is being blown into the cylinder (which is at TDC firing stroke) you can then turn the air pressure up and listen.
Open the oil cap. Do you hear any air (kind of sounds like putting your ear in a big shell, the seaside noise)
Unplug a vacuum line. Do you hear any air (sounds like a minute air leak coming out)
Listen out the tail pipe. Is there any noise? (sounds like a very deep air tone)
Depending on where the air is escaping, you will then know where you are losing compression from. If it's coming out the oil cap, you know your rings are the problem. If it's coming out the vacuum hose, you know your intake valves are leaking. And likewise, if you hear it coming out the exhaust you know you have a problem with your exhaust valves.
We can perform a leak down test for you here at Secret Services, as well as do this diagnosis to help you find the problems with your car, and thus work towards making your car 100% once again.
Mattback
Mattback
rest in peace tim.
rest in peace tim.
