need some advice from some dsm owners
i was about to put a 6 bolt in mine, but im not doin over 350hp or anything, so i am just puttin a nother 7 bolt in mine....they are good, the reason mine blew was not from the power, so dont get worried about that, but if you are willing to put the time into working on the car yourself, then youll be saving alot of money for whatever mods you want to put ion it or fixing stuff
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
on the t-25?
Anything past 15psi is probly just blowing hot air... i think fuel cut is like 18psi so you could run that much, but i definately wouldn't recommend it just because it's pretty much pointless and stressing the turbo a lot
Originally Posted by TRIPLE G
Be care of what you read on either of those sites.
There is alot of mis-information on them.
Edit: Also don't worry about crankwalk, just check for the normal symptoms such as the clutch sticking on left turns.
so i probably could put it to 15 and not have to worry about a single thing ? i really appreciate this alot guys thanks anyother mods that are good to do right off the bat would be great to know as well thanks
