oil light
my oil pressure gauage doesn't work for some reason, but starting today, the oil light comes on until i rev it past 2k then it goes off and stays off until i start the car next time. anyone have this problem before, or know how i can fix it?
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
SEE NO EVO HEAR NO EVO!
One of the pressure sending units are bad, or you have a loose wire connecting the sending unit, mine did that for the oil warning, but i had aftermarket gauges with perfect pressure shown, so i just unplugged it. But i dont think you have another gauge, so you might want to get it fixed.
SUCH IS THE RULE OF HONOUR.
where is the oil pressure sending unit on the motor? i can get a gauage tomorrow, that little light just scares me a little.
^^^There is a little plug that can come loose.....or just decide to screw with you. Check it out.
