Boost Whistle
Old Mar 3, 2005 | 02:07 PM
Gst_LmJ's Avatar
No longer has a DSM :(
Default Boost Whistle
I have a 1999 GS-T
About 2 weeks ago I installed a Greddy Profec B spec II in my car, and ever cince then, I have been hearing this loud whistling noise, really high pitched, it starts at about 10psi, and it only happens when im giving it about 60/85% gas, sometimes it sounds when I give it 100% gas, it sounds like its coming from the intake side of the engine, but somtimes it sounds like its coming from the turbo Im not sure if its a blown turbo or a vacumm leak, does anyone know what it could be? thanks for the help
Old Mar 3, 2005 | 02:16 PM
Brothers's Avatar
TR Balla Donor Supreme
do you have a t25 or 14b turbo cause my brothers car was doing the same thing and it was the exaust side of the turbo had a crack in it
FullyBuiltInc.com
Brothers
A.K.A
Rob and Dave
Old Mar 3, 2005 | 02:17 PM
Ep41382's Avatar
sounds like a leak somewhere, check all the fittings etc...maybe also try adjusting your bov if you can, try tightening it up some
Eric
AIM: Ep41382
Old Mar 3, 2005 | 02:22 PM
Gst_LmJ's Avatar
Thanks, im gonna try that, and yes i have the T-25, i have checked pretty much all the vacumm hoses for leaks, but i only hear the noise when boost is over 10psi, and i cant really rev the car on neutral and get 10 psi...
Old Mar 3, 2005 | 02:55 PM
GsEclipse02's Avatar
put it up on bricks and give it gas dumb ass jfwu
Old Mar 3, 2005 | 04:24 PM
BoondockSaint's Avatar
plumcrazy
+1 on check the bov
Old Mar 3, 2005 | 04:26 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
how much shaft play is there, may be the death whine since your seeing more boost out of it
SUCH IS THE RULE OF HONOUR.
Old Mar 3, 2005 | 06:30 PM
LS1Fever's Avatar
you either have a crack in the exhaust housing or your turbo is finally on its last leg. take the inlet pipe off and check for shaft play, bend fins, or broken fins. the sound is definitely your turbo.
Old Mar 3, 2005 | 10:26 PM
Ep41382's Avatar
just b/c there is a whistling sound doesnt atuomatically mean this turbo is shot, jesus....could be a number of things
Eric
AIM: Ep41382
Old Mar 3, 2005 | 10:39 PM
BoostLogik's Avatar
BoostAddict
It most likely is a leak coming from somewhere. I too had this high-pitched whistle that you are describing. Come to find out, my HKS SSQ and the flange popped out of the I/C pipe (was working on the car that day and I had to remove it then re-install it), thus creating the whistle pitched sound.
Check all around for boost leaks and try checking/adjusting the BOV, as mentioned before.
"Even through the darkest days, this fire burns, always"
