Dsm
Old Jan 18, 2005 | 02:18 PM
Riptide101's Avatar
Default Dsm
Have a friend that has a 97 GST and he is looking to start modding it. He has found an APEXI down pipe and full catback APEXI exhaust. From what he and myself understand, there is no cat when you use both of these. Will he get a check engine light because I understand there is an o2 sensor after the cat.
Any info would be appreciated. We don't want to see the dreaded CEL unless you guys no a way around it.
Old Jan 18, 2005 | 02:45 PM
Brandon's Avatar
Resident Dingo
not sure about the apex but ive got the turbo back greddy and i havn't had a chk engine light flip on me.
--brandon
Old Jan 18, 2005 | 03:17 PM
TampaTSi's Avatar
you might get a cel at first, but probably not. i got a code when i messed w/ my exhaust, but it went away and never came back. if you do, have autozone clear the code and it won't come back.
1998 Eclipse GST
Old Jan 18, 2005 | 03:19 PM
BoostLogik's Avatar
BoostAddict
The check engine light is probably on because the 2nd O2 sensor was removed and never reinstalled. I have to do some research, because I am not sure about whether or not you can get rid of the check engine light for the missing "cold" O2 sensor.
"Even through the darkest days, this fire burns, always"
Old Jan 18, 2005 | 03:47 PM
Riptide101's Avatar
Thats what we are worried about. Even if the aftermarket exhaust or downpipe has a bung for the o2 sensor, I think if installed, it will throw a code thus fudging up the way the car runs because the ECU will try to compensate or correct it.
I figured someone else on this board has tried this and encountered this problem.
Old Jan 18, 2005 | 06:13 PM
Skillionaire's Avatar
Nobody
It wont effect the way the car runs. Its only there for emission control, dont worry about it.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Jan 18, 2005 | 07:04 PM
Shaun_GST's Avatar
<<<Tampa<<< >>>Bay>>>
i have the same exhaust, my check engine light and i are one. i never let him outta my sight
Gripped XS | 18-55 IS | 50mm f/1.8 MK II | Sunpak 5000af
Old Jan 18, 2005 | 11:03 PM
LS1Fever's Avatar
If it does not have a spot for the second o2 sensor, go to any exhaust shot and have them weld in a o2 bung. I didnt have a spot in mine when I had my custom exhaust made. The o2 bung is like $10. Never had a problem.
Old Jan 19, 2005 | 02:05 AM
Shaun_GST's Avatar
the apexi has the bung already
Old Jan 19, 2005 | 06:19 AM
dsm's Avatar
dsm
rice sleeper
it will throw a code when u remove the cat
2010 Evo X MR
12.3@110mph
344whp/375wtq
Jalvarez Studio
