greddy profec b
Old Nov 19, 2004 | 07:12 PM
boosteddsm's Avatar
Awd the enemy of fwd
Default greddy profec b
need some help on setting the boost? Was wondering what settings others were using on a 16g? what ever i do seems like it wants to keep over boosting.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old Nov 19, 2004 | 08:50 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Those things are a pain. My friend has one in his 240sx and it is nothing but trouble. When you say you are overboosting, what do you mean? I'm guessing you have the warning function set up and you keep getting the annoying red flashing? There are two main ways to overboost. You're probably either spiking or creeping. If boost shoots past your set boost and then settles back down, you need to play with the gain to get it to build boost slower and start opening the wastegate sooner. If you're creeping, nothing short of good portwork or raising your boost level will cure it. If your boost is set to 17 psi and your alarm is at 18, then you have a case of expecting too much of the unit, because they seem to vary up to 1 psi or more at times. I'm not really clear on how the warning system works, but I'd bump it up to 2 psi variance if that's an option.
Old Nov 19, 2004 | 08:57 PM
boosteddsm's Avatar
i went back out a lil bit ago and messed with it some more ive got it at around 17-20 psi but on stock 450`s dont know how safe that can really be!!!
Old Nov 19, 2004 | 10:13 PM
LS1Fever's Avatar
as long as you have a fuel pump, you should be safe. i ran a big t28 w/stock 450s at around 22 psi w/no knock and 28-32 degrees advanced timing
Old Nov 20, 2004 | 07:02 AM
FastEclipseGSXT's Avatar
still overboosting/creeping? if so what are your settings?
Jeremy
www.myspace.com/biggrapes01
Old Nov 20, 2004 | 07:16 AM
boosteddsm's Avatar
have start boost at .24 gain at 12% and set at 2%
im not positive but that sounds about right, wife has car right now so i cant check it.
Old Nov 20, 2004 | 02:01 PM
MadisFastDSM's Avatar
tractionless
i have a 16g too and i have a blitz ssbc and when i have mine closed all the way on low boost it creeps to like 16psi in the high r's its because the o2 housing needs to be ported... wastegate also
collision and refinising technician need bodywork/ paint call 727 776 7830
Old Nov 20, 2004 | 05:03 PM
pimpin's Avatar
pimpin
madisfastdsm still want to sale si spoiler call me at (813)967-2571
