power/ time estimates on setup
Old Nov 1, 2004 | 05:44 AM
Ian MMF's Avatar
Omnipotence
Originally posted by N1_STYLEz
also... what would you guys recomend next? injectors, s-afc, and suspension are my next guess on what to put on it... then id do a few personal touches to the interior so that it a little better (seats, harnesses, steering wheel, better system, etc.)... and what should i get for tuning? he said something about how he had a palm to tune it with but he didnt have the cable to hook it up with... does this sound logical to anyone? is there a program out that you can use a palm pilot with to tune or something or am i just reading it wrong? once again... thanks so much
-Josh
Since when did mitsu make a shitty head? Last time I checked stock head cars were well into the 130s. Just cause it's not ported or 5 angle blah blah blah doesn't mean it's not good. And I would find out who ported the head, the mitsu head is kind of funky so if the person doesn't know exactly what they are doing it could actually hurt performance believe it or not.
Oh and you'll mid to low 13's if you up the boost most likely.
Old Nov 2, 2004 | 07:38 PM
N1_STYLEz's Avatar
SAVE THE SOHC's
I didnt say that mitsu made shitty heads... i just said that the head on the car was shitty... its all messed up and the valves arent sealing properly... he's got a new head that he's throwin into the deal that is ported and has a 5 angle valve job and is resurfaced... and i have another queestion... how good are the sheppard trannies? do they have the stock gear ratios? whats so different about them that makes them so much better besides double synchros on 2nd?
-Josh
'91 EF Civic Hatch(daily)
'93 GSX (in the making)
Originally Posted by 94lsTEG
Originally Posted by geoff
either way he still stomped my ass
ummm you own a civic...get used to it!
Old Nov 3, 2004 | 04:15 AM
Ian MMF's Avatar
Omnipotence
-Josh
Go read his site, it will tell you everything you need to know. Shep trannies are to live and die by.
Old Nov 3, 2004 | 05:19 AM
dsm's Avatar
dsm
rice sleeper
what 16g is that? if its the super 16g from hahn, then right now with no injectors u can with tuning run about 13.5-13.8's at 105-107mph. thats what i was running, with about the same mods. get a fmic, afc, and injectors, tune it and boost it to 25psi, and u should see high 12's. my best with the s16g was 12.7@112mph
2010 Evo X MR
12.3@110mph
344whp/375wtq
Jalvarez Studio
Old Nov 3, 2004 | 12:56 PM
Rich's Avatar
Old School.
Stock injectors and no front mount? I wouldn't expect anything better than 103-104 mph as other have stated. Not that it hasn't been done, you just don't see it happen often.
You may know who we are, but we KNOW who you are.
Old Nov 4, 2004 | 02:30 AM
N1_STYLEz's Avatar
SAVE THE SOHC's
ok thanks a lot for the info... yes it is a super 16g... its ported as well as the manifold and the O2 housing... your adivce was very helpful and i think thats what im going to do as far as my next mods... probably an afc first, then a fmic, and then injectors... does that sound good? one queston though... you have a 2g fwd... its a 1g awd- wouldnt the 1g be faster because of a better launch, its lighter, and the stock head flows better than the 2g(thats what i heard)? would that lower my times significantly? as far as injectors go, i've heard of going to the junkyard and getting the injectors from 2 RX7's (because they are so big they have only 2 each) and getting them flow tested and blueprinted... does this really save a lot of money and does it work good or is it just some lies a kids telling me?
Old Nov 4, 2004 | 03:38 AM
  #17 (permalink)
Ian MMF's Avatar
Omnipotence
Why go through all that trouble when you can buy injectors any size you want for like $70 a peice pretty much anywhere that sells them. Please don't ghetto rig your shit, there is already enough dsm's like that out there. If your going to do it do it right otherwise you'll end up paying more in the end.
Old Nov 4, 2004 | 09:56 AM
  #18 (permalink)
MitsuBucci's Avatar
Olde Skool DSM'r
550s are all over ebay for $205.
660-880s for $280.
I've been 107 in a full weight AWD with stock injectors and 118 in a "lightened" FWD Laser with stock injectors.
Joe B.
Wrenches, Races & Rides
Old Nov 4, 2004 | 01:42 PM
  #19 (permalink)
N1_STYLEz's Avatar
SAVE THE SOHC's
660-880s for $280.
awesome... thanks a lot guys for all the help... ill keep you posted on whether or not i get the car... im in the middle of setting up a time/ place to meet him right now
-Josh
Old Nov 4, 2004 | 02:00 PM
  #20 (permalink)
Ian MMF's Avatar
Omnipotence
660-880s for $280.
Did any of those MPH's you noted involve the use of a wet nitrous kit?
Just wondering
