94 Eclipse Compression questions
OK...found out the problem with the 1994 Mitsu Eclipse...
(4-cylander 1.8L engine)
Sparks plugs/wires and ignition and fuel pump and radiator are all great and working. Did a compression ratio on the 4 cylanders, from right to left (if you were looking at the engine).
1st cylander-getting about 5-8 psi when trying to start car
2nd cylander-getting about 65 psi
3rd cylander-getting about 65 psi
4th cylander-getting about 65 psi
Question- is this a blown head gasket (is was running hot before) or is there a problem with the cylander?
The car tries to start, but sounds sick turning over, as if it can't get that final kick. Obviously due to compression.
FINALLY- IF it is the head gasket, I am sure I can replace it pretty easy myself (did one on a '88 Cougar V6 w/np). If it is not, is there anyone that would be willing to fix for some cash? I don't have a lot, but will supply all beer needed! Thanks all...
