Eclipse Shakes
A friend of mine has an 96 Eclipse and her car shakes when she is braking from over 40 mph. No rotors are warped. Brake pads are fine. Just want input on what it is.
how are you sure the rotors arent warped?
SUCH IS THE RULE OF HONOUR.
i took them off today and looked at them.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
you cannot always tell by looking at them if they are warped, i do brakes all day long and none of them look warped until you put them on a lathe to actually shave the warped part, just looking by eye is not good enough, and more than likely that is your problem, buy some new ones or get them shaved, warped rotors will cause shaking and vibration under hard braking conditions or faster speeds, a common problem
they are new rotors, replaced less then 1 mo....ask for the hard braking, it is not just hard, it is everytime she brakes
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
