Eclipse Shakes
Old Oct 4, 2004 | 08:42 AM
JDMBlackGSR's Avatar
Gators Bitches!
checked that too
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Oct 4, 2004 | 11:29 AM
4gpusherny's Avatar
check her lower control arm bushings , where lower control arm hooks up to frame . those usually cause that problem at 40 mph , most people dont happen to think about that right away
NYCCDSM MEMBER , GONE OUT V8
HUNTING !!
Old Oct 4, 2004 | 12:08 PM
Gators Bitches!
i will check that out....thanx
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
Old Oct 4, 2004 | 01:16 PM
4gpusherny's Avatar
no prob
HUNTING !!
Old Oct 4, 2004 | 03:23 PM
BoostLogik's Avatar
BoostAddict
90% of the time, it is the brake rotors. The Eclipse rotors are garbage. Even though her rotors are new, just her driving in the rain, making sudden quick stops, or braking from high speeds, will warp the rotors rather quickly. Still a possibility.
Her wheel bearings may be going bad also. Usually when someone replaces their rotors and still get a "vibrating" feeling, wheel bearings are usually the source of the problem.
"Even through the darkest days, this fire burns, always"
