atmos. bov + safc
Old Mar 25, 2004 | 04:43 AM
Rich's Avatar
Old School.
Originally posted by PoppaSmurf
no, it wont, it only corrects for hot wire style mass air, your car is a karman vortex.....the car will run like shit, just recirculate the damn thing
The type of air metering does not make a difference. If you blow the air off and you are metering before the turbo, its GONE and you have accounted for it, regardless of the metering device.
You may know who we are, but we KNOW who you are.
Old Mar 25, 2004 | 04:59 AM
Ian MMF's Avatar
Omnipotence
If you want to run open atmosphere bov just buy an afpr and bump up the fuel pressure a bit. Not that big of a secret.
Old Mar 25, 2004 | 05:40 AM
Rich's Avatar
Old School.
And adding fuel to a bunch of lost air does what?
Old Mar 25, 2004 | 06:18 AM
PoppaSmurf's Avatar
Chowdah-head
making it run richer than it already will, great idea!....what i meant rich, is that the s-afc will allow to correct the stumble when you shift, but it will still run pig rich, it only partially corrects, i still recommend recirculating regardless, just stating tht with a karman style meter, your basically screwed, lol
Poppa J. Smurf
Old Mar 25, 2004 | 03:40 PM
flubyux2's Avatar
Elitist Supra Asshole :)
uhm... an SAFC has the Decel correction function to correct the airflow count when the BOV is vented. again, this only works on Hot-wire type cars. Karmann wont work.
Bumping your base FP wont help either, itll make it WORSE. the reason it stumbles and bucks when the bov vents is cuz of the lack of air, or excess of fuel... bumping the FP will accentuate this problem
the only real way to do this is to place the MAF after the bov, converting to VPC, or get an HKS SSQV. these stay closed during idle. so when you let off the throttle, the vaccum is at 22 in/hg, and will cause the BOV to vent, but the SSQV will shut as the vaccum reduces and engine returns to idle and the engine will catch it self and not die out... but it still doesnt keep the engine from running rich inbetween shifts. this of course is a problem when trying to reduce transient boost lag and will cause your plugs to foul up faster.
Karmann meters are the BOMB for stock systems, but are hacker-unfriendly. they precisely meter every unit of air, first hand. a hotwire or map sensor only knows how much air is coming in via correct calculations and tables preprogrammed into the ECU. anyhow, i wont get into this stuff right now...
basically venting is a bad idea unless you have the right equipment. and yes, it does sound cool... admit it, there's a little bit of ricer in all of us.
