what do u guys use to tune?
Old Dec 26, 2003 | 06:03 PM
lancerman's Avatar
Tuning by EGT is very effective.
Tuning with blinky light can be effective but takes alot of time. It is best to use this for idle and part throttle cruise only.
The best tuning is done with a logged wideband signal. Without being able to log the signal it is no faster or better than a good EGT.
Best tuning tools I own are my peak hold egt and new generation g-tech. You can dasil it right in very quickly with these two onboard.
my favorite quote
Old Dec 26, 2003 | 11:39 PM
eclipsegst303's Avatar
.:DSM:.
Originally posted by Sneakin Deacon
good luck getting correct o2's with a narrowband and a pocket logger... in my honest opinion, a wideband o2 will tell you much more than any EGT guage...yea, that 1 guage will tell you what that 1 cyl temp is.. but what happens if one of the other 3 have a failing injector? your only monitoring the one cylinder and wont see much temp if any increase unless your monitoring the cyl w/ the bad injectors...a wideband o2 in my opinion is the number 1 possibly most constructive tool/monitoring device, that should be equipped in any modified car. and when you think about it...alot of people tap the EGT into the driverside runner, #1? that is the coolest running cylinder if all are running the same...the air has a greater distance to travel to get to that very last runner, and in turn its getting a richer mixture in that cylinder because its getting less air then the others...but this is just my theory id monitor the cyl closest to the TB as it has 1st dibs on any air coming through but still your left with the fact your only monitoring 1 cyl.
the reason everyone taps the number one runner is cuz its the hottest. and the reason that i have heard is because it gets the fuel last.
Old Dec 27, 2003 | 07:40 AM
Sneakin Deacon's Avatar
PSSHHH x2
gets the fuel last???? wow, lemme guess, your flux capacitor is using all the fuel right?
base fuel pressure is around 36psi i think in dsm's...that means that fuel rail is pressurized with fuel lookin to go somewhere (to the injectors) its not choking the injectors by any means..
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Dec 27, 2003 | 08:53 AM
Dizin's Avatar
Alive Yet Again
SneakinDeacon check them pms
almost dumped 07 SI
