EGT external warning Buzzer / light
Old Nov 13, 2003 | 10:03 PM
slowy's Avatar
13.04@104mph
Default EGT external warning Buzzer / light
i think i remember Bucci had a buzzer hooked up to his EGT gauge. i was looking at apexi website and came across their PDF manual.
http://www.apexi-usa.com/productdocu...haust_temp.pdf
on page 4 it says that the orange wire is for "warning output signal (for realy)"
does that mean i could hook up an external warning light or buzzer by using a relay?
any help would be greatly appreciated
Old Nov 14, 2003 | 02:07 PM
Mr 2's Avatar
New Member
yes
Old Nov 16, 2003 | 04:06 PM
MitsuBucci's Avatar
Olde Skool DSM'r
The orange wire is triggered to a ground when "warning" is reached. I had a small piezo buzzer with the positive hooked to 12v and the negative hooked to the orange wire. If you are running a buzzer or light that uses any real current, you should use a relay.
Joe B.
Wrenches, Races & Rides
Old Nov 17, 2003 | 09:44 AM
slowy's Avatar
13.04@104mph
i was thinkin of just using like an Alarm LED, or a superbright LED from circuit city.
so i'd run the positive side of the LED to a HOT wire and the negative to the orange?
thanks man
