DSM help
My GF's 95 gst is starting to eat up oil. I was thinking she just went to long without changing the oil but she is sure that there is only 3000 mile on the oil, " I would change it then anyways
She was really worried about it so i checked the charge pipes for oil but none was found, " The turbo was in realy good shape suprisingly" the only other thing that i can think of to do is give her a compresson test to make sure the rings arent goin.
Does anyone have any other suggestions for me that i can do so she doesnt have to go to a shop and pay for a shit load of labor.
thanks
mike
P.S
Smurf dont say ull look at it and she can pay u back in other ways!!!
You cant even put your board shorts on right stoner
"She was really worried about it so i checked the charge pipes for oil but none was found, " The turbo was in realy good shape suprisingly" the only other thing that i can think of to do is give her a compresson test to make sure the rings arent goin.
thanks
mike
P.S
The Schnoz Berries Taste Like Schnoz Berries
AIM: TegraRacer97
AIM: TegraRacer97
dammit, foiled again.....ok, check out under the car and see if it is leaking exterally, check the oil feed line, oil return, and oil filter housing, those are probably your best bets for an external leak, also run a compression test, it can never hurt, there are a bunch of other possibilities, but start there and see where it takes you
Poppa J. Smurf
Poppa J. Smurf
