12a motor questions
besides bridge porting what else can i do to the 12a for performance i dont know anything about the motor
What do you mean its broke? Oh, some electrical tape will fix that.
Electrical tape fixes anything
I love the 12As and you can get nice HP out of them withOUT killing your pockets..
On a 12A your port work is not limted,it depends on how deep yoru pockets are.
You can go from a nice street port to a Perifical port.
12As already come STOCK with 3mm apex seals,So no thrown out cash for milling the rotors,BUT keep in mind anything bigger than a street port,will widen your power band,Meaning you need some internal mods.I would recommending putting more dowl pins in the engine too.$$ involved.
Higher pressure oil regulator,Harden stationary gears,rotor clearance,balanced rotors/E shaft etc etc..
12As make nice power gains with bolt ons,since its a 4 port engine,you DONT have to worry about 5th and 6th ports being stuck or actuators not working,POS enginering.
Yes you can go turbo,you can use the stock 9:4 compression rotors.
Pending on what carb set up you run ..you may have to make a turbo bonnet for duel Webers or buy a bonnet for a Holley,do a blow through set up,alot of 12A guys run T60s,anything in the 60s T60,T61,T66,etc
Theres a nice amount of 4 port Turbo 12As running 10s on the track,ALOT of them from Miami,
Parts are cheap for a 12A.First gens are one of the best bodys out of the RX7s for drag....
Why?
You can drop ANY rear end you like,Ford 9,Ford 8.8,GM 10 Bolt,
I seen anything from Linco,G Force,Jerico trannys in first gens.
Wieght of the first gens are nice,and can be gutted to your imagination,Nice shell before going into 3/4 chassis.
Any questions..just post..
Why?
I KNOW U DONT LIKE 6 PORTS BUT CHIL OUT WITH THE PROFANITY TOWARDS BETTY!!!!
pssst.... thatz my car's name ...
lol jack
lol jack
image removed from your sig...see forum rules
