It’s not often that we feature the same car twice on Speedhunters; especially.......
Old Dec 27, 2016 | 09:49 AM
Default It’s not often that we feature the same car twice on Speedhunters; especially.......
[h=1]Old Rotary, New Tricks: Checking In On A Favorite[/h] CAR FEATURE
Words Mike GarrettImages Louis Yio 13th September 2016 28 Comments
It’s not often that we feature the same car twice on Speedhunters; especially not in the span of a year. But Phil Sohn’s FD3S RX-7 is a unique case.
Easily one of the most well known RX-7s on American shores, Phil’s Mazda is a car that’s constantly evolving inside and out.
In fact, when I first saw images of the updated car I had trouble even recognizing it as the same machine that we showed you guys last year, such is the work that Phil has put into it since.
And it’s not like this is the first time Phil has changed things up. Since he first acquired the FD back in 2003, the car has gone through many different stages, some unrecognizable from the one that came before.
This is just the latest iteration of a car that Phil has owned for much of his life. The same car he and his wife used on their second date way back when. The same car that his son experienced his first ride around the neighborhood in.
Phil has many friends who have also built highly modified cars, and he has often seen them struggle to find motivation once their cars are complete. Sometimes the cars get sold off to a new owner, while other times they wind up sitting and collecting dust.
Phil has treated his RX-7 as something more; he takes as much satisfaction from constantly changing the car as he does from sitting back and looking at a ‘finished’ product.
So what has changed on the FD since the last time we saw it? Well, there are a number of things, including a few notable alterations to the exterior.
Gone is the chameleon color of the previous version, swapped for a much subtler, handsome shade of metallic gray. The front bumper has been changed to a Japanese Knight Sports item, and the rear end now features a carbon fiber ducktail wing.
The previous iteration of the RX-7 had Ganador mirrors, but it’s now sporting a pair of fender-mounted carbon fiber items to further differentiate it.
There have also been some updates under the hood, namely the switch to a BorgWarner EFR 8374 turbo setup.
Old Dec 27, 2016 | 09:52 AM
Not surprisingly, Phil has also changed out the FD’s wheel and tire setup. This time around he went with a set of Gram Lights 57FXXs from the RAYS catalog.
The wheels measure 18×9.5-inch +25 in the front and 18×10-inch +20 in the rear with Toyo Proxes T1 Sport tires all around.
[h=4]SECOND CHAPTER[/h]Unbroken Bond
The cockpit of the RX-7 has seen significant changes as well. Gone are the custom gray upholstered seats of before and in their place a more traditional set of black Bride Vios III buckets. Another big change is in the dashboard, which now sports a custom-integrated iPad setup which functions as tachometer, speedometer and a display for many sensors.
Other custom touches include a new carbon fiber hatch cover that Phil made himself, something he believes might be the first of its type in the world.
Despite the constantly changing nature of the car, Phil isn’t fickle or unwilling to commit to a particular style or theme.
If anything, he says the constant tinkering and reinventing has only made him build a deeper bond with the car.
Yet even with all of the changes he’s done to the RX-7 over the years, he knows at heart it’s the same machine that’s been with him for so long.
And after years of building and rebuilding, Phil has become deeply familiar with every part of the Mazda.
Needless to say, we expect more changes are on the way for Phil Sohn’s ever-evolving Mazda RX-7 and we can’t wait to see what the next iteration has in store.
Old Dec 27, 2016 | 09:53 AM
Mike Garrett
Instagram: japanifornia
mike@speedhunters.com
Photos by Louis Yio
Instagram: lusciousy
Phil Sohn’s 1993 Mazda RX-7
Engine
Mazda 13B-REW engine, dynamically balanced rotating assemblies, intake port matched to 13B-RE, 13B-RE polished lower & upper intake manifold, BorgWarner EFR 8374 turbocharger, custom throttle body adaptor, carbon fiber cooling panel & grounding kit, Adaptronic modular ECU, Turbosmart Kompact Shortie blow-off valve, IWG75 BorgWarner TP B2 single/twin scroll, Davies Craig water pump, Chase Bays coolant overflow tank, ABS delete kit, Samco intercooler couplers & coolant kit, Injector Dynamics ID1300 fuel injectors, Full Function Engineering adjustable motor mounts, fuel rail kit, oil filter pedestal, trigger wheel kit & fuel kit, Defi oil temperature sensor & oil pressure sensor, Radium Engineering competition oil catch can, surge tank & fuel filter kit, Walbro E85 pump, Koyorad N-Flow radiator, fast acting air temperature sensor, A’PEXi GT Spec front mount intercooler kit, HKS Twin Power ignition system, FEED oil filler cap & coolant filler cap, Sakebomb Garage spark plug wires, Setrab 25-row dual oil cooler kit, Braille light battery, vertical mounting kit, Unorthodox Engineering alternator pulley, cut aluminum main pulley, Jester’s Toybox Rein Hard dual titanium catback exhaust system, FEED stainless steel resonated mid-pipe
Drivetrain
Factory FD3S 5-speed manual gearbox, Exedy twin-disc clutch, transmission brace
Suspension & Brakes
Tein Flex Z coilovers, Tein EDFC Active Pro, PowerFlex Black Series bushings, M2 launch kit, R-Magic fender braces, Racing Beat sway bar brace, rear sway bar, sway bushings, Tri-Point Engineering front sway bar, Mazdaspeed strut tower brace, Nagisa Auto Shakitto strut tower plate, Sakebomb Garage/AP Racing big brake kit, Ferodo DS2500 brake pads
Wheels & Tires
RAYS Gram Lights 57FXX 18×9.5-inch +25 (front), 18×10-inch +20 (rear), Toyo Proxes T1-Sport tires 255/35R18 (front), 265/35R18 (rear)
Exterior
Dip Your Car custom blended Plasti Dip, Knight Sports Type 7 bumper, JDM vented hood, EVO-R LED taillights, diffuser LED light, carbon fiber fender mirrors, CR3 Motorsports washers, FEED carbon fiber side skirts, wide fenders, front tow hook, door handles, carbon fiber gas door, R-Magic HID headlights, Herb Motorsport custom front bumper signal lights, carbon fiber ducktail spoiler, Rotary Extreme hood dampers, Adam Griffith rear tow hook, Efini badges, Sanai carbon fiber rear diffuser, Back Off third brake light flasher
Interior
Raceshop roll bar, Tein EDFC controller, EVO-R carbon fiber gauge cluster panel modified for iPad Mini, blank shifter panel, Defi Link Advance controller unit, Smart Adapter, Link Meter Advance BF gauges, Davies Craig digital EWP controller, Grip Royal Royal Teggi steering wheel, titanium bolts, metal crest horn button, Bride Vios III Type R Japan Edition carbon fiber racing seats, Takata Race 6 Hans harness, Race 4 harness, FEED shift knob, carbon fiber door step, carbon fiber trunk add on, Works Bell short hub, Herb Motorsports carbon fiber privacy hatch cover, RZ floormats, carbon fiber interior panels, LED interior lights, Custom 60mm center speaker gauge pod
BONUS CHAPTER
Cutting Room Floor
Dec 20, 2025 10:02 AM
Jul 3, 2021 03:43 PM
Nov 10, 2016 07:22 AM
Guado
Nissan/Infiniti Tech
12
Oct 24, 2004 03:43 PM
