1988 rx7, do I need an engine?
Old Jul 22, 2009 | 03:54 PM
iskate2's Avatar
wears black
Default 1988 rx7, do I need an engine?
So I went out of town for a week, and left my 1988 rx7 with a 91 engine daily driver on the curbside. When I got back I found my battery dead, so I put a new battery in it. Now when Im cranking it over, it sounds like theres no compression. I put a spoonful of marvel mystery oil in it, and still it sounds like no compression. spinning over waaaay too fast. Is my engine done? anyone with a rotary compression tester want to help me out?
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
Old Jul 23, 2009 | 09:47 AM
Niburu's Avatar
Sic semper tyrannis
where did you put the oil?
basically you've lost all compression in the motor
pull the egi fuse
crank over it about 20 times in 10 second bursts
put the EGi fuse back in
the engine should start
2011 Subaru Forester - the daily driver kid hauler
1990 Miata - track whore
LOVE THIS TAMPA CAR RACING SCENE
Old Jul 23, 2009 | 07:22 PM
rotarykidd's Avatar
ROTM February 2013
easy way to check for compression is to just put a reg tester in it and crank it. if the needle bounces you have compression. the needle wont stay so youll need some one else to help. but it does work, ive done it
Old Jul 23, 2009 | 08:31 PM
iskate2's Avatar
wears black
cool thanks guys ill try the cranking trick. Ill try and get back to you
Old Jul 23, 2009 | 08:40 PM
landon303's Avatar
dude dont even bother getting a tester, pull a plug from each housing, leading plug is better. crank & if you hear even, strong sounding pulses from each rotor then your good. my guess on the turning fast thing is that you've got the wrong battery & it's throwing to much current to the starter, thus spinning it faster. I honestly think it's flooded really bad, in which case the MMO trick will work, or as the above pullling the EGI fuse (electornic gas injection) or letting it sit for a day or 2 w/ the plugs out. Theres no way it just blew sitting there. dont be an idiot and put ATF in the motor to deflood it either please. g/l
engine, not motor
Old Jul 24, 2009 | 12:13 PM
markstheman365's Avatar
cant slide
this thread seems really helpful..i know this is off topic. but i left the honda game and am joining the rotary world. i should have my fc by christmas. and you guys dont seem like the homosexuals with hondas lol
contact admin@tamparacing.com to advertise on here.. - mod
Old Jul 24, 2009 | 05:00 PM
iskate2's Avatar
wears black
shit worked. thanks amigos
Old Jul 24, 2009 | 10:48 PM
zammm's Avatar
ZAMMM
was it flooded? my FD with 1600cc injectors has been flooded. I just get someone to push my car around with their car while I'm in gear. It forces all of the extra gas out smokes a bit too
Old Jul 26, 2009 | 05:41 AM
landon303's Avatar
spider cracks.
engine, not motor
Old Jul 27, 2009 | 12:41 PM
Niburu's Avatar
Sic semper tyrannis
iskate2 may not have even flooded his engine, there is usually one or two "sweet spots" where the motor will completely lose compression if it sits
I've had it happen a few times, 10 of the ten second starting bursts seemed to always do it, also premixing may help alleviate this and leave a nice lubricate apex seal to hold the compression better
Zammm watchout on how many time you flood the car, after about 5 floods the plugs tend to get fouled badly, my FD wouldn't start on cold days till I changed out the plugs
