Cold air intake and water problems
Old Jul 28, 2009 | 12:46 PM
Niburu's Avatar
Sic semper tyrannis
Originally Posted by Rallysport_josh
got it dyno at petes auto shop. cause i have 239 lbtq to the wheels and all i have is a intake and exhuast
only if you have a Mazdaspeed3
and according to your profile you don't
try 148hp/135tq for that 2.0 you have http://www.edmunds.com/used/2004/maz...212/specs.html
2011 Subaru Forester - the daily driver kid hauler
1990 Miata - track whore
LOVE THIS TAMPA CAR RACING SCENE
Old Jul 28, 2009 | 05:39 PM
ANGRYEAGLE's Avatar
TRURED SPEED3
So this will only affect Mazdaspeed3 ? Cause I was considering 1 for my Speed3.
Old Jul 29, 2009 | 05:39 AM
Niburu's Avatar
Sic semper tyrannis
the affect will be more noticeable on an FI car like the speed3
it won't give an NA motor the ridiculous number that genious up there was claiming.
If you're asking about hydrolock from sucking in water, then yes that affects all piston powered cars, rotaries not so much.
Old Jul 29, 2009 | 06:06 PM
Slo_RydP5's Avatar
Ryce Hater
u can buy preventors to put on ur CAI to keep the water from entering into the intake mani....i think AEM makes them..i forget what they r actually called but they're out there
but if ur that worried about it buy a SRI....
Old Jul 30, 2009 | 06:52 AM
Niburu's Avatar
Sic semper tyrannis
it's called a hydro sheild, they work pretty well as long as you don't actually submerge the intake in water
Old Aug 6, 2009 | 07:31 AM
Nealio's Avatar
Atenza-fied
Hydro Shield won't protect you from submerging your filter which is the big problem concerning CAI. If you drive through a puddle that is deeper than it looks, and your filter goes underwater, you are SOL.
The only thing that will protect you in that situation is one of these.
AEM intake bypass filter. You insert this as a coupler at some point in your intake system, and if the filter goes underwater, this will allow you to suck air from the top of the engine bay and prevent a hydrolock.
OBX - AWR - Megan Racing - Injen - CP-E - Greddy - ProSport - Corksport - Medieval Motorsports - Apexcone
Nikon D5000
18-55mm f/3.5-5.6G AF-SDX VR - 55-200mm f/4-5.6G I AF-S DX VR - Ziekos 52mm CPLs
Old Aug 7, 2009 | 06:48 AM
  #17 (permalink)
somestone's Avatar
Nealio Is Correct But You Gotta Remember As A Rule Of Thumb Don't Go Across "lil Puddles" Of Water Too Fast !
Wide Open Throttle=more Suction= Possible Bypass Failure=hydrolock....
Just Run A Longer Pipe Down And You Should Be Safe..
