Need help with roatary!!
Old May 12, 2009 | 07:34 PM
Jesus24's Avatar
Default Need help with roatary!!
look the car wont shut on it turn over and over and over .. well u get it but it just wont shut on... it has spark its has fuel going thru battery is good.. but it was sitting there for a while what do you think it could be .. on the dash it also says shift up.. what does that mean.. its an 88 fc rx7 13b
Old May 13, 2009 | 05:24 AM
NI_racing's Avatar
not sure what it is that your asking about. If the car has been sitting for a while with old fuel in it it could be an issue anywhere from the tank to the injectors and/or anywhere in between. COuld be plugs, coils, wires. If the car has fuel and spark, it'll start, for the most part. Relax and take a step back, then look at all the basic parts required to start the car again. After you go thru those again, id check the vacum hoses and see if theres a leak somewhere. Also check the oil level why your at it, just to be safe.
Tampa Bay Rotary Owners Club Member # 4
PIT KREW
TEAM MEMBER
________________
Team Decep!
you never saw it coming
Old May 13, 2009 | 04:04 PM
Jesus24's Avatar
thx bro figured it out the fuel lines are clogged up! u will be repped ! i did put new fuel in it
