S4 idle issues
Old Feb 7, 2008 | 12:18 PM
elitist's Avatar
TR Balla Donor Supreme
Default S4 idle issues
I have a TII s4 and at idle it wants to idle at 2k and pulse to 2300 RPMS, any ideas what that could be? Also the car is bogging badly and doent want to go past 4k RPMS.. any ideas???
Old Feb 7, 2008 | 12:58 PM
RX007CYM's Avatar
Lucky
https://www.tamparacing.com/forums/m...e-problem.html
Wish I had more for you dude, but FC's arent my expertise. Hell FD's arent either!
Originally Posted by JustMiata
It's like this: The toadstool juice fires through the unicorn injector into the fairy dust chamber, where the tiny wizard does his secret work...Then a gang of keebler elves get hopped up on the crystalline byproduct of the wizard's tinkering, (they smoke it) and then the elves push the spinning triangle through a series of dimensional portals to a final realm codenamed the "exhaust port..." At least that's my undersanding of rotary sorcery...
Old Feb 7, 2008 | 05:06 PM
Rx7_guy's Avatar
3,800 RPM hesitation aka shitty grounds
FC3S Pro v2.0:&nbsp FAQ - 3,800RPM Hesitation
JDM FC
Old Feb 7, 2008 | 07:08 PM
elitist's Avatar
Ok well is there a secondary throttle on FCs? I found a rod that goes up to the throttle from the bottom area of the engine that the previous owner had tried to zip tie back on but had come off, so I put it back on there and put a cotter pin on it etc. Also the rear intercooler pipe was loose, and a few other problems... I flooded the car BADDDDDDDD lol and now I am waiting for it to air out some to see if that fixed my problems but we shall see!
Old Feb 7, 2008 | 07:31 PM
Rx7_guy's Avatar
Oh...that rod is for the oil metering pump that is very important! It a control that allows oil to lubricate the housings.
JDM FC
Old Feb 7, 2008 | 08:47 PM
elitist's Avatar
ooo glad I caught that haha
Old Feb 11, 2008 | 06:36 PM
rexaholic7's Avatar
I BURN OIL N I LIKE IT!!!
you just blew a piston ring. very common on these damn rotative thingys
Originally Posted by jonBODON
that guy has more skill in his left pinky toe then your whole body...
Very Proud Member of R.A.P.S.
R.A.P.S member number #0003
Rotaries
Against
Piston
Swaps
Old Feb 11, 2008 | 06:43 PM
seventhgear's Avatar
hanglike sleeve of wizard
also calibrate ur tps maybe
image removed from your sig...see forum rules
Old Feb 12, 2008 | 09:07 AM
elitist's Avatar
damnit! I knew something serious was wrong.. gawddddd
Lol but in all reality it is a massive boost/vaccum leak, I fixed 2 of them and gonna boost leak test it tonight and fix the rest... its taking a while but slowly I'm fixing all the stupid problems this car had/has.
