fuel level sender resistance
Old Nov 11, 2007 | 11:44 AM
Sneakin Deacon's Avatar
PSSHHH x2
Default fuel level sender resistance
for the 88's, does the fuel level sender use the 0Z(empty) - 90Z(full) rating? im making an aluminum dash setup and am going to go with an aftermarket guage but need to figure our which to get.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Nov 11, 2007 | 04:09 PM
sharingan 19's Avatar
"Da Man"
there is only one after market gauge that will be accurate w/ the stock sender. It's made by autometer and it's adjustable.
The stock sender reads like 7ohms empty and around 115 full, so if you find a 10-110 ohm or so gauge it shouldn't be too off.
I've got a custom dash in the works too, but that fuel gauge is holding me up ..........$100 ftl.
"If losing you are yet no mistakes you have made, a different game you should play" - Yoda
Old Nov 11, 2007 | 09:04 PM
PSSHHH x2
worse comes to worse ill just fab up an aftermarket sending unit for it but wouldnt mind being cheap.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
