turbo 2 engine swap
if you really serious talk to Japan2LA on rx7club.com. He always has alot of swap parts, ecus, pressure sensor, mafs/afms. Watch out for what kind of ecu you get. if you get a jspec ecu it will have a speed limiter on it along with the boost cut, usdm ecus only have boost cut.
Kick ass. I'll do that, I've been lookin for a MAF for my N/A so I can put an intake on it, but I can't find any info whatsoever on that matter. Appreciate it alot
Originally Posted by Ayn Rand
"Just as I support my life, neither by robbery nor alms, but by my own effort, so I do not seek to derive my happiness from the injury or the favor of others, but earn it by my own achievement."
Buy a t2. It will cost you more to do the swap then it will to buy a decent running t2. If you do decide to do the swap you can use an s5 motor and change the front cover, omp, water pump, etc to s4 stuff. Then use an s4 harness and no wiring issues, but with the benefit of s5 engine and turbo. Use a t2 tranny though. If you're too cheap to buy a transmission then you shouldn't be considering the swap.
NBDT!!!
NBDT!!!
Tell me about it
