View Poll Results: Which route would you go?
Voters: 23. You may not vote on this poll
1990 Vert project
On rx7club.com there is a guy named Japan2LA and he sells used JDM motors. He is an rx7 freak so he will tell you what the compression numbers are and make sure you get an S5 motor/tranny. He also sells low compression motors for cheaper because they would need to be rebuilt. But a good compression s5 TII motor/tranny is $1250+shipping from him, it will be a great motor. Hes in L.A. if you didn't catch that by his name. I messaged him about 1month ago shopping for a motor and he had (2) good compression S5 motors and (1) good S4 motor. He's your best shot for a good motor for sure, your not going to find a s5 TII motor locally but you can drive up to Ocala and pick one up personally for $1200.. Good luck, I'm in the same boat as you, I have a 91' black hatch that needs a turbo drivetrain
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
or u can luck out and find a whole drive train & even a rear end.ecu/harness/fuel pump/ etc... the list goes on from a guy that bought all the shit with intentions of making an n/a 2 a turbo2, but lost interest... hell that's how i got mine
image removed from your sig...see forum rules
Just bought an OMP because the old one has gone to shit. gonna get the true dual setup going after i install the pump. but since this is my girls car, hopefully i can pick up the 10 AE in the f/s section if no one else does and do that up pretty good.
