rotor keys!!!
Its no diffrent than cutting any other key.Maybe he was a janitor,just filling in for someone on lunch break.
So how do you like it so far?
If some dipshit vuts it wrong,give it back and ill get you another one.
Originally Posted by AbortRetryFail
I got one too - the fucker at lowes wouldnt cut it because his jackass doesnt know how to run the key machine.
Joe, i drove past that place the other day. Are they open saturdays?
DO NOT GET THESE KEYS CUT AT LOWES OR HOMEDEPOT. TAKE IT TO A PROFESSIONAL WITH ONE OF THOSE OLD STYLE KEY CUTTERS. IF YOU ASK SCOTT AT MAZSPORT HE WILL TELL YOU TO DO THIS. THE NEW MACHINES WILL MESS UP YOUR KEY AND HE WILL NOT WARRENTY IT.
it looks like the key is cut to fit the slot of the rotor, and then a rivet is put in place, and then drilled flush with the rotor. may be cheaper for tony to have that done, or something like that. whatever.
engine, not motor
engine, not motor
Originally Posted by Rotary7
I got my key cut at Lowes,
And if you got the key from ME,and it was cut wrong.
I will warrenty it.
I will warrenty it.
say if it does brake..
I just get another key put in,and if yours brake.. your shit out of luck...
My key does NOT have any problems fitting into my car,its not loose nor to tight.
Originally Posted by Rotary Buddha
yours will break soon. i bet it doesnt fit so snuggley into the door or ignition.
1986 Mazda RX7 GXL - "Champagne"
134.7 RWHP - Going slow in style
