F.C Tranny Swap worth it ????
Swapping out a N/A FC tranny worth it ?
Whats a good swap that would work 7x better ???
TII tranny swap, R1 Tranny swap ???? Any suggestions that would fit perfect please respond back.
- CoRDiTe
- CoRDiTe
I made two threads. disreguard the other one. computer was lagging and hit refresh and re-created. didnt know the other would go through...
- CoRDiTe
- CoRDiTe
If your staying n/a -ported-or some bolt ons,the n/a tranny will be ok,pending on your clutch set up..
If your set up is more mild,bridge port,maybe with 100 shot.. I would say step up to a TII tranny,but then you need to change flywheel/drive shaft/clutch or just get a FC Efeni tranny,the gear ratios are suppose to be closer..
if your building a street/ strip 7 you will want to get the t2 tranny maybe a jdm lsd for better gearing but if you are not looking for anything much over stock like bolt ons and stuff then the n/a tranny is fine
mike
mike
Mike
Tha Stereo kid
Theres NO reason to try and fit a FD tranny in a FC,if your running to much power for a TII tranny,id go Jerico, G FORCE or something along that line..
