87 RX7 non-turbo questions
Old Apr 5, 2005 | 02:57 PM
CoRDiTe's Avatar
Not Mad
but to stick a camden supercharger you have to already have a Turbo motor. you cant use a N/A right b/c of the compression right ???? Plus if you did use a Turbo motor. don't you have to retard the ignition, and coil ignitors for the spark plugs ????? and reset and fine tune your coil and ignitors and ignition for the Super charger to work ???
Old Apr 5, 2005 | 03:19 PM
Rotary7's Avatar
Get Down-Or-Stay Down
should of clicked the link,I thought it was for the carb ser up,didnt know they came outy with a FI set up for 6 ports
The Rx7 Supercharger EFI Kit has the capabilities of bolting right onto your 86-91 Non-Turbo Mazda Rx7 13B Engine. This Supercharger EFI Kit will give you approximately 176 horsepower using your stock fuel injectors. If you are looking to get more horsepower in your rotary, you will need to increase the flow capacity of your fuel injectors. Using your stock Mazda Rx7 13B ECU, we estimate you will get 35% more horsepower at the wheels by increasing your injector flow.
Do you want to be tazed?
Old Apr 5, 2005 | 05:23 PM
cheerboy's Avatar
honda john
run the fuel pump up so when u turn the key it onthen u have no rev limed thats what i did to my and it mad it ten times faster
Old Apr 5, 2005 | 05:30 PM
Rotary Buddha's Avatar
zero pistons
the fuel pump turns on when you turn the car on to begin with.
serious though ive got a 87se with a ton of mods now if you want to check it out some time im located over in tampa by usf
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old Apr 5, 2005 | 05:45 PM
cheerboy's Avatar
honda john
my frined has a 86 rx7 with a brand new motor that only has like 5 hours on it and he want to sell it i think hes only askin a 1000 its a 13b full brigport and t2 tranny in it is nices as fuck if i had the money i would get it but i dont its at his shot if u want to know more about it the shop is called CDS and the # is 727-898-5108 ask for little mike
smoke3
Mar 7, 2004 02:02 PM
Dabwuigwe
Feb 28, 2004 06:53 AM
Nismo Turbo SE-R
War Stories
Aug 30, 2002 09:38 PM
