Turbo questions...?? need advice
Old Feb 25, 2004 | 02:22 PM
Dabwuigwe's Avatar
Digga
Unhappy Turbo questions...?? need advice
Just getting into turbo more... right now running all motor LS b18b...I've got a stock block.. but I have head mods on the car
My questions... Would a Garrett T25 be worth my time or money?
I can get one for $100... rebuilt great condition
I have crane stg 2 cams...can these be used with turbo.. low boost....???
and I would be ok running low boost on stock internals until I could afford upgrades right???
Old Feb 25, 2004 | 03:01 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
1. No.
2. They CAN be, but you wouldn't really want to.
3. Yes.
Old Feb 25, 2004 | 03:06 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
i wouldnt use that turbo, its a waste of time and money especially considering you wont be able to find a manifold that is flanged for that turbo.....
Those cams will actually make you lose power on a turbo app... turbos need a shorter lift and longer duration to make their full potential and those all motor cams you have would not do any turbo justice....
and I think that even on stock fuel you would be ok to run about 6-7 psi on like a 50 trim t3t4 but that turbo will also give you plenty of room to upgrade later and it works beautifully on the LS....
Hope that helps
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Feb 25, 2004 | 07:29 PM
RONIN's Avatar
Tetris on a stick
Hope that helps
backwards, higher lift, low duration for forced induction.
high lift high duration all motor... depends on where you want the power.
what are the specs on your cams?
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Feb 26, 2004 | 07:05 AM
Dabwuigwe's Avatar
Digga
ok... so definitely T3/T4....... what cams should i go with?? I just sold my stock cams for $20..... I heard LS cams suck anyhow
Old Feb 26, 2004 | 09:37 AM
Dabwuigwe's Avatar
Digga
this is what i'm asking you... T3/T4 has to do with size and trim right???
Old Feb 26, 2004 | 09:55 AM
99B16Si's Avatar
T3/T4= the turbine(hot)side of the turbo is a T3, the compressor side is a T4
u can find a set of ls cams for less than 20 bucks, i would use those and make some money off the ones u have now.
and ronin is right, u want more lift instead of duration. duration is the amount of time the valves will stay open per cycle, if theyre open too long you increase the chances of higher cam overlap(when the intake and exhaust valves are open at the same time) and the boost can just blow right thru the cylinder and never be combusted.
