Injector problem
Did you read my post? They don't do anything at idle, only above 3800 RPMs. So your diagnosis of having bad secondary injectors is probably incorrect. So what is the actual problem you are having that you think it may be your secondaries?
Originally posted by 93g2integra Chris
Neither of my secondary injectors are working, unpluged them both and engine idealed the same, and sound the same under load. Has anyone else had this problem?
This sounds like a terrible diagnosis. Do yourself a favor and search and post on www.rx7club.com Loads more info than can be found on this whole site.
