94' Honda CBR F2 / Freshen up
Old Mar 31, 2010 | 05:34 PM
Hybrid Motorsports's Avatar
Default 94' Honda CBR F2 / Freshen up
This bike has been sitting for several years, So when the customer pulled it out some attention was needed.
First we had a charging problem; So we went threw the charging system,
1. Tested battery- which had a dead cell
2. Tested stator output
3. Tested wire for shorts & grounds & for good Earthing
4. Tested regulator / rectifier for possible bad diodes
Now were getting ready to start & run the engine to do a dynamic system test under load. This is when we find out....
Number 2 & 3 cylinder carbs are flooded so bad it's coming back through the carb, Well we knew a carb clean & sync was in order based on the time it sat So here we go.
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
https://www.tamparacing.com/forums/hybrid-motorsports/
Old Apr 2, 2010 | 07:21 PM
Default Update
Well carbs, jets, bowls & passages cleaned, time for reassembly..
O check out this before & after side-by-side
So all good re-installed and now she runs!.. presto!
Now to finish the charging system....... and we're charging.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
