what motor setup should i run??
if i had more time i would go into detail... but taking out and building a D and all the turbo accessories, machine work, labor and everything is not cheaper than swapping in a K. K's are very common motors for swaps now and are not that expensive. shit, you can get an accord/crv k24 longblock for $700! which is less than the d- pistons, rods, rings! lol
My car isn't fully back together...at least not in the shape I want to sell it. I won't get what I need out of it...$1500 is for how she sits now, I will be asking $2000. I have to swap the head.
does anybody know what kind of wiring im dealing with when it comes to swapping the z6 head in using my obd0 intake mani and dizzy?keep in mind id like to use an obd1 vtec ecu.
Sleeper.
TR "F#UCK Thieves" crew member #6
Sleeper.
bro, listen. rods, pistons and rings are about 900 alone! there is no way a built d will be cheaper than a bolt-in k-swap. no way. i have done them in eg's. a lot easier, less time involved and a thousand times better motor/trans.
ive seen base model k- series go for 1300. and ive seen typ-s k series swaps go for 5000.
IMO building a d for boost is cheap and still carries plenty of potential. building n/a on the other hand is a waste IMO
i wish there was a good write up using an obd0 car that already has multi point.
Sleeper.
Sleeper.
