ls crank and rods in c1 block
Old Jul 14, 2003 | 01:45 PM
Hybrid_eg's Avatar
i like the blue ones
Default ls crank and rods in c1 block
i have a knife edged ls crank and a set of shot peened ls rods layin around can i use them in my c1 block and what pistons should i use? will have ctr and itr cam setup with oe deck heights, also which bearings ls or gsr
Shut yo ass up nugguh..
ReginaVagina
Old Jul 14, 2003 | 06:04 PM
NChatch's Avatar
i stepped on my weiner!
that is the TRUE LS/vtec setup!!! finally
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jul 15, 2003 | 06:35 AM
KJ's Avatar
KJ
bored at work
use ls bearings and whatever pistons you want. Make sure to clay check everything.
Old Jul 15, 2003 | 09:39 AM
Hybrid_eg's Avatar
but will it push the pistons out of the hole due to the difference in cc brtween the two motorsand also can someone tell me how to tell the differences between cranks i believe it is a ls crank but could be a b20 crank no sure
ReginaVagina
Old Jul 15, 2003 | 09:42 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
NO DIFFERENCE IN B20 AND LS CRANK. I HAVE A B20 CRANK IN MY LS BLOCK AND IM USING TYPE R PISTONS. CRANKS ARE THE SAME
tamparacing.com
Old Jul 15, 2003 | 10:53 AM
Hybrid_eg's Avatar
ok but by using the ls crank in my gsr block will i push the pistons out of the cylinder (using ls rods as well)
ReginaVagina
Old Jul 15, 2003 | 01:21 PM
Y2JAY's Avatar
Originally posted by KJ
use ls bearings .
why
Old Jul 15, 2003 | 01:25 PM
Hybrid_eg's Avatar
i changed it to cylinder but anyway still need to know if it will put the pistons out of the cylinders at all
ReginaVagina
Old Jul 15, 2003 | 03:46 PM
99B16Si's Avatar
Originally posted by Y2JAY
why
LS rods need LS rod bearings
all b-series main bearings are the same
the longer stroke from the LS motor is caused from the different rod to stroke ratio not the blocks deck height. the pistions skirts will not have a problem with passing the deck height.
