no vtec
Old Jul 6, 2003 | 09:55 AM
95civex's Avatar
Sorta Kinda O.G.
Default no vtec
Ok...Im having a similar problem like "spoonfedbaby" When I accelerate...around 5 grand...car just bogs down and feels like it is going to stall...I dont keep on it...I just let off the gas and switch gears..so I dont know if it will actually stall or not...but anyway....this motor has been in my car for like 4 or 5 months now and before now..it hasnt done this..except for one time....at like 5...it felt like my rev limiter kicked in early...but now that I think of it....it was probably doing the same thing it is doing now...its a b16/gsr head and Im using p72 ecu.....could it be the vtec silenoid???
Old Jul 6, 2003 | 10:36 AM
NChatch's Avatar
i stepped on my weiner!
throwing any codes at all??
have you checked the fuel filter lately, or oil volume, low oil= no vtec, but im sure you have already checked all the basic crap
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jul 6, 2003 | 12:21 PM
95civex's Avatar
Sorta Kinda O.G.
hmmm fuel filter...havnt checked yet...but oil...I just changed my oil last week...so hopefully that isnt it....I ll check on the filter tho thanks....any other ideas?
Old Jul 6, 2003 | 01:25 PM
Miles's Avatar
It's a wooden pickle.
with it bogging like that, i would say check the fuel system (filter, maybe clean the injectors, etc.)
Old Jul 6, 2003 | 06:18 PM
blazinSTi's Avatar
cant hold it much longer
engine makeing any knock noise check nuts on cam gears maybe loose just happen to me
Old Jul 8, 2003 | 04:05 PM
95civex's Avatar
Sorta Kinda O.G.
Ok guys...thanks for the replies..but...I bought a new fuel filter and checked oil...still doing it...acceleration is terrible...and now its more like 4 grand when everything just bogs down and feels like the engine is going to cut off...My friend mentioned distibutor...you think this might be the problem??? I hope to find someone to let me borrow one first ..before I buy...
Old Jul 8, 2003 | 05:33 PM
95civex's Avatar
Sorta Kinda O.G.
HELP!!! ttt
Old Jul 8, 2003 | 05:52 PM
PCouv's Avatar
Member
I'm kinda having a similar problem. When I accelerate the car starts jerking and bogging as if fuel isn't getting throug. My check engine light came on and I had it checked and they said the code that it through out was map sensor going bad. Because you map sensor is what controls your fuel maping and tells the ecu how rich or lean to run the fuel as well as air fuel ratio. I still need to get my map sensor replaced. So yeah, check that out. I'm pretty sure it's the map sensor. Let me know how every thing comes out.
Old Jul 9, 2003 | 10:45 AM
95civex's Avatar
Sorta Kinda O.G.
hmm thanks for the reply man...but Im only throwing the o2 sensor code..since I dont have one hooked up
